Why can't I hear anything through the baby monitor?
Baby monitor is plugged in but no audio.
Hello,
I have this issue as well. What it is... The microphone wire within the camera becomes loose over time. This is due to the turning and spinning of the camera as you pan the room. You should be able to spin it until it catches the wire, bringing sound back to the microphone. In my case, if I turn the camera to face the left upper corning of the room, I will regain sound. I can then move it back to the baby, and keep sound until my wife moves the camera.... after I tell her not too.
It worked! Thank you!
This worked for me too! You siir, are my hero!
Thank you! Totally worked!
Oh my gosh I’ve been trying to figure out what was wrong with the sound the last few weeks! I didn’t even think of panning around more until it worked! Thank you!!!!
This was SO helpful. I actually went through creating an account here just so I could post a comment and THANK YOU, sir!! Phew!! Thank you so so much for posting this. Did the trick!!
First, locate the volume button and make sure it is set to a high setting. If it still doesn't work, then the speaker is faulty and will have to be changed.
Check the Replace Speaker Guide on instructions on how to change the speaker. Infant Optics DXR-8 Speaker Replacement
Past 24 Hours: 10
Past 7 Days: 48
Past 30 Days: 200
All Time: 38,285
4 Comments
I have the same issue except I hear static and the visual bar on the left of the baby monitor no long lights up green to red for any sounds.
by petephat Share
same thing is happening to me, did you found a solution?
by denis Share
I’m having the same issue: no lights, no sound just picture on the monitor. Has anyone found any way to fix this?
by akoenders Share
Same problem here. The issue is certainly not with the speaker on the receiver, as some sound still comes through when placed on the highest volume (8, for some reason). When you blow air directly into the mic, the lowest indictor light still lights up. Any real solutions?
by Alex L Share
